I get that sometimes, one file starts within a second and an almost identical MPEG2 file takes 20 seconds to start or just doesn't start at all when the next time it does start.But for some reason it takes a long time to load each video.
Hmmm, maybe pulling out the 4GB memorystick from my PSP and using that is the easiest option<snip>
Hmmm, maybe pulling out the 4GB memorystick from my PSP and using that is the easiest option![]()
Woohoo!
After posting earlier about my WMV-HD files with 5.1 sound not working... well, no audio, I tried a HD DivX file with 5.1 sound.
It didn't just work, I got 5.1 sound... FROM THE XMB!
There's a first!
I've tried 5.1 MPEG2 files before on the XMB, and it's always downconverted it to Stereo... same with mp4.
The DivX I tried was a TV ep from the states, with DD5.1, and my amp definitely switched to 5.1 to play it back. That's a real improvement, 5.1 fro the XMB.
V1N.
Lol someone's excited
VideoRedoPlus never worked for me. The 360 would play MPEG2/DD5.1 TS files converted to MPEG-PS but the PS3 never did. So now I use TSRemux which you can change TS files to M2TS. It plays them. Whether you get DD5.1 I don't know as I no longer have that speaker setup.
Well try changing the container from TS to M2TS with TSRemux. It's a free program and will only take a few minutes...
http://forum.doom9.org/showthread.php?t=125447
Rebooted the system just now, dug the file back out of the recycle bin, played it, yep, played fine with 5.1 sound, so yes,Do xvids work over streaming?
I haven't been able to get it to work.
sid
edit/ which folder do you have to keep them in? I have them in public videos in vista, sharing enabled, its picking up audio fine but not any video??
Sorry, I wasn't clear, streaming has worked fine for months but as I do not have a personal computer running 24/7 I wanted to know if I could use a program to copy the DIVX files over the network to the PS3 harddisk instead of trancoding and saving them, but I guess the option of turning off transcoding is in TVersity so I will try that and see if the program makes a copy of the file without doing anything else.Same goes for Dutch Guy btw. If you can translate the above to your Dutch version of Windows (assuming you're running a Dutch Windows) then you should be able to stream and/or copy files to your PS3 too, as you asked about above.
Probably best you don't mention that sort of stuff here, the mods won't like it.V1N be really nice if you did a pictorial thread on the subject...
Covering what does and what doesnt work inc screenshots.
Im mainly interested in:
Chances are these still have to be converted/altered
And my Windows is in English as I have been used to that for years now and whenever I sit behing a Dutch Windows version I have to look for stuff like Control Panel and Add/Remove Programs![]()
