- 2 Feb 2008
Sorry to open this old thread again.
My FAT PS3 has died and I am getting a PS3 Slim.
I have downloaded the latest software update onto my USB Stick as I believe this is needed after replacing the hard drive in the PS3 Slim.
I recently fitted a larger capacity hard drive (640 GB) into my FAT PS3 and I am wanting to use this in the PS3 Slim. I believe it is a fairly easy job to replace the hard drive in the PS3 Slim, but I was wondering will the data etc on the 640 GB hard drive work OK with it been used in the FAT PS3 or will I run into some compatibility issues after putting it into the PS3 Slim?
Thanks in advance.
Thanks in advance.
, is there anyway that I can backup the data, saved games, videos, games etc off of the 640 GB hard drive, then install it into the PS3 Slim, which would then format it. Then after this, restore back the data, saved games, videos, games etc back onto the 640 GB drive that would be then in the PS3 Slim
