2.5" SATA 9.5mm
Sorry I should have been a bit clearer, I meant size as in GB capacity.
Don't know but no drive of the correct physical size has exceeded its storage limit yet.
In short, you can buy whatever drive you want as long as it fits.
Can't fault Seagate at all. A few people I've known have had a drive of theirs die. I've had in excess of 50 in the last 5 years and only one has gone defective. You won't hear any noise a 7200 RPM laptop HDD will make outside the PS3 anyways.
Your suppose to use 5400rpm hds in a ps3 aren't you as 7200rpm can cause incompatiblity problems?
well according to this video :
Someone hurry up and try a SSD in a PS3
Im tempted...
ps3ud0![]()
Someone already has, vastly increased installation times for only marginally (10% ish) quicker loading times.
