PS3 HDCP Protection
Permabanned
9 Dec 2010
Not sure about linking these days on here so pop "hdcp stripper" into a well know rainforest site. and check out the WINGONEER 1x2 HDMI Splitter.
I have a few for when I have to stream PS3 games at events over hdmi. works fine.
I tested a similar cable to your 3rd option, and it didn't event output any video at all.
Hopefully the sellers might be able to help, but I haven't found any that work consistently for as cheap as you are looking. Good luck :)
Just a quick heads up incase anyone else had the same question.
I bought the following splitter for £8.63 delivered and it's worked an absolute treat - http://www.ebay.co.uk/itm/111515463895.
I'm assuming that any splitter that look the same/similar to the one I posed will work fine. Some sellers on eBay are charging £20+ for the same bit of kit above.
