I decided to upgrade the hdd in my PS3 so I ordered a 320gb Scorpio drive and a 2.5" external enclosure.
Stage One (this is as far as it gets), I put the 320gb drive in the enclosure and backed up the PS3, thats strange I thought, 27gb was used on the disk but the backup folder was only showing its size as 3.5gb.
So I try backing up again and it creates 23gb folder, so now I know something is wrong with the previous backup and possibly the caddy/drive.
I copied the larger back up off the drive onto my mac, put the 320gb drive in the ps3 and copied the backup onto an old 3.5" external drive (original plan was to copy the backup to the original ps3 disk and put it in the 2.5" enclosure but I'm feeling somewhat paranoid now)
Restore operation fails error 800283F0, can't find any information on this, wonderful.
I'm pretty certain now either the 320gb or the caddy is at fault. I presently have WD Diagnostics running on the 320gb drive having removed it from the PS3 and put it in my PC and am backing the PS3 up again from its original disk directly to the old 3.5" drive to bypass the 2.5" caddy.
THIS WAS SUPPOSED TO BE EASY.
