- 18 Feb 2007
- London
hi
i own a 40gig ps3 and im reading up about changing the hardrive to something bigger, but im not sure if i need to , if i only use it for games and blu-ray should 40gig be enough ?
if i download demos i normally delete them after ive tested them , its just im unsure how much memory saved games take up is it a lot?
is it possible to upgrade in the future and transfer all data to the new hdd
cheers
cheers
. If you only play games and blu-ray and delete demos when you've played them, then i think 40GB is fine for you. Its only worth the upgrade if you constantly download HD content, keep demos and are wanting to use the PVR when it comes out.
