- 2 Dec 2006
I think it's quite a funny conversation. Besides what more can you say about the video? He's a moron. Sorted.
That is because of the air inside the balloon and is nothing to do with it's mass.
f=ma
and
f= GMm/R^2 where M is the mass of the earth and R is the radius of the earth
ma=GMm/R^2
a=GM/R^2
a=g as the acceleration is mavity. Showing that the acceloration and thus speed of a falling object is only affected by the mass of the earth not the mass of the object. I do maths at uni btw
If you fired a bullet parallell to the ground and you droped a bullet from the same height, both would hit the ground at the same time as well
:EDIT:
G is the gravitational constant not mavity.
On a side note you can see why a black hole is black. It is becuase the radius is so small and the mass so large that its gravitational field is so strong that it prevents light from escaping.
Also you can see from the equation that the higher up in the sky you go the weaker mavity gets because you are increasing the radius. Thus your terminal velocity will increase the closer to earth you get.
Mass surely does make a difference when not in a vacuum. There will clearly be a resultant force on the object due to air resistance and this will take into account mg. Hence a water filled balloon will fall faster than an empty one of identical shape.
f=ma
and
ma=GMm/R^2
a=GM/R^2
.:EDIT:
. Well explained though. The thread was derailed long ago, this is just a more interesting direction i think
