ps3 mains fuse help?
18 Feb 2007
London
hi there
im not that glued up on mains fuses and stuff but would like to know what fuse i should be using in the ps3 mains plug?
reason is ive got a clearer audio copperline alpha power lead laying about but it has a 13 amp fuse in it , i just looked at the ps3 orignal lead and it has a 5amp should i switch it to the 5 amp?
thanks
Yes you should switch it to the amp used in the original PS3 cable.
But i have to ask, why bother? It won't affect the functionality or reliability of the PS3 in any way what so ever.
proberly correct ,but its more tidy and shorter than the ps3 one , i was using it on my hi-fi system but ive sold it so need to use it or i wasted £30 quid , well ive already wasted it buying the thing
cheers
