PS3: Media streaming problem, stuttery...
Don
23 Oct 2005
North Yorkshire
Guys,
Just streaming some video's to my PS3 from my PC using TVersity. The vid loads up fine but every say 10 seconds it stutters as if its buffering liek a internet video? Or is it buffering? Any ways to stop this or speed it up???
I had the same problem. It was due to my wireless router sending mixed B and G type signals. I set it to signal only G type signals and now it works a treat.
If your router can send either signals then there should be an option under the "Wireless" settings, called 'Mode' (followed by B-only, G-only or Mixed). I can't tell you exactly since all routers and even some firmware have different setting interfaces.
On the other hand, if your router is only capable of sending one type of signal then you can't change anything.
I used to have a B only router, so I went out and bought this one Linksys WRT54GC because the PS3 doesn't receive B signals very well.
Well changing to g only didn't work, thans for the suggestion though
CPU usage is 12% so nothing out of the ordinary. :(
Any other ideas? I had the same problem when streaming to the 360, but that was always displaying "buffering"
Gah, still doesn't work...
I know for a fact I bloody watched the video the other week and it was fine, why can't it be simple!
I also got the "UPNP Not Available" But it fixed itself when I changed to G signal. I guess you should ask on the official Playstation forums if another answer doesn't come up here.
