PS3/Monitor Problem
30 Dec 2010
Cloud 9
Hi guys
Im looking to connect my ps3 to my monitor but my monitor only has 1 connection that my graphics lead plugs into.
Is there a splitter i can but to maybe put in the back of the monitor that gives me 2 ports to plug ps3 and graphics lead in ? Would save a lot of messing about having to swap them all the time.
Thanks.
dont think there is a 2 into 1 cable, but there will be a box you can buy, where the two DVI plug into, and then you switch between them using the box.
just had a google using "dvi video splitter box" term, there is a dual link dvi cable and various boxes and such.
Thanks will look for one on ebay ;)
And vanandjuanunited it only has DVI port on my monitor.
