PS3 Move Sharp Shooter vs Logic3 Machine gun
27 Sep 2005
Burbage, Hinckley
I fancy a gun for playing Killzone 3 with Playstation Move. The Official Sharp Shooter seems a bit steep at £35-£40 though and I have seen a Logic3 version on the bay for £15.
Anyone know if there is a lot of difference between them?
Knowing logic 3 products, build quality will be the massive difference.
I also prefer the idea of button usage and joystick movement being controlled by different hands. On the Logic 3 model the same hand will be pressing nearly all the buttons and using the joystick.
There's a few reports of the trigger mechanism breaking on the logic 3 gun, however i don't know whether that's luck or a design flaw.
As with anything mate you get what you pay for, I can't imagine the logic3 one being any good.
Not used the Sharp Shooter in game but had a fiddle with one at work. Build quality is decent and it seems like it would be comfy to hold and play with
