PS3 Move
29 Dec 2005
Northants
Ok so I brought the move bundle a little while ago and it seems very temperamental, it seems to work with the sports champions game at least as far as I'm aware. I managed to get it to work ok with Resident Evil 5 once, tried it with the Heavy Rain demo and it didn't work at all just went all over the place I dunno if I haven't set it up right or my room is too dark or small?
The camera does seem pretty grainy when you do the initial calibration of putting it against your shoulder then your belt buckle.
I put the controllers n camera away after use as it gets in the way otherwise.
Hope someone can help I can't test it till Tuesday but any help would be much appreciated.
I have the sports champions and a golf game, both are very responsive. Maybe the wide screen isnt selected? My PS3 is in the livingroom which has plenty of room. Maybe you are too close. But if it works with one game then it should be ok with all.
Yeah same here, the actual move capture is near flawless. Beats the Wii and Kinect, by a garden mile in that aspect.
Things I'm not too keen on is the grainyness of the camera itself and the bulb glows quite bright. Its a little annoying if the lights are dim. But other than that, its been my fav between the Kinect and Wii.. Actually even thinking about sending the Kinect back.. Can't be having all the gizmo's cluttering my TV.
