PS3 MS Slot
16 Dec 2003
Halifax , UK
Just A Quick Question About The Menory Stick Slot, I Have A Spare Memory Stick Duo Pro 2GB Card So Thought I Would Stick It Into The PS3 For Some Extra Storage.
Using The Supplied Memory Stick Adaptor It Came With, The Card Slots nearly All The Way Into The Slot On The PS3, And I Can Only Get It Out With Some Small Nose Pliers As Enough Isn't Sticking Out To Grab It With My Fingers.
Is This Normal?
I find the memory card reader on my US PS3 to be a bit hit and miss. I've got an SD card that works every 2nd attempt, without fail.
And as said, push in to eject.
AND TURN CAPS OFF ;)
Is This Normal?
no probs here, you sure your sticking it in the right slot? :p
theboyrob said:
Is This Normal?
yes
there shouldnt be any sticking out to grab with your fingers because as said you push it and it springs out
you possibly broke the mechanism pulling it out with needle nose pliers :eek:
Is This Normal?
Is typing like that normal? No, not remotely :)
I have sorted it, works fine just the duo card. Only seems to say MS pro on the slot though so thats why i was using my adaptor.
Sorry about the typing, my PDA decided it was going to put a capital for each word :|
Thanks anyway :)
