PS3 - one question
12 May 2005
Does the PS3 have a VGA? I was thinking of getting them on the first real price drop/set of games I want comes out.
But I play using a 20" widescreen, does it have VGA?
No, not at the moment. I suppose it is possible that they could release a VGA cable later on.
HDMI > DVI doesnt work either unless your screen has HDCP.
Its quite annoying as i'd like to use it via VGA or DVI, but cant. You can buy a box that will convert component to VGA, but they cost £50ish.
Im personally trying to find somewhere that may stock one of these -
http://www.hdfury.com/
