PS3 Possible Sound Connections
5 Feb 2008
I have currently got my PS3 connected to a Pc Monitor via HDMI to DVI cable. As my monitor does not contain any speaker connections, is there any possibly ways of getting sound with out buying a new monitor?
You can use the optical out (TOS-Link) on the PS3 to output to a suitable amp or speakers. I think you can do the same with the analogue ports on the standard AV cable as well. You have to change the audio settings in the PS3 once you do this. The video will still come out of your HDMI>DVI connection.
rp2000
