Ps3 Problem , Any Advice ?
Permabanned
2 Feb 2010
Haywards Heath
My mates playstation froze in the middle of a game lastnight so i turned it off by the main gave it a min and turned it back on and now there is no picture and the tv says no signal but the playstation is on and once it is on i cant turn it off by the power button what would that be if you could tell me what i need to do with it that would be great it is the old 60 gig one cheers :mad:
All i can suggest is hold the power button when you switch it on until you hear a second beep. This second beep signals that the PS3 has reset its video settings and, assuming there's nothing physically wrong with it, it will then work.
I mean hold the power button on the console. If that doesn't work there's a way to get into a recovery console that i've forgotten but i'll try to find out how to do it again.
Mine done this last week,try pulling the plugs for your tv & ps3 from the mains socket.Switch back on after a minute or so, keep finger on the power button until you hear the second beep & let go
This worked for me,hope it helps
Rob
