PS3 problem.
26 Nov 2005
Doon the Bay (Newcastle)
Hi There,
I'm away from home and thought i'd take me PS3 with me but its set to hd 1080p, and the tv is a old crt so using composite via scart setup only the TV won't display or detect the PS3 due to the higher resolution.
I've tried doing a reset, but can't get 3 beeps out of the console, mainly just on a beep then off, sometimes i get two beeps but no signs of a reset.
I was hoping some kind soul who's got 5 mins to turn on their console and give me a up left, x x right kind of instructions to the resolution menu and to turn it to 480 or composite via scart settings?
Thanks.
Hold down power button for like 5 seconds?
Should hear one inital beep, then irrc two beeps and it should reset to the default.
EDIT: :(
EDIT: :(
Ok so its not 3 beeps together (first time i've heard that thanks), well i think it has done this several times then it turns itself off, is that what is supposed to happen? I'm guessing not :(
turn it on with no tv connected should detect no tv, plug tv back in and it should go to the initial setup
Worth a shot but that hasn't worked either. The Tv's scart detects other hardware no problem, but I've never tried the PS3 via composite before, could be a dodgy connection or lead, no way of finding out right now.
At least reign of fire is on, half decent, should see me through the rest of the night. :(
Strange that the reset thing is not working but I find it really hard to play go from HD to SD with modern consoles. Ok on a master system or something but trying to play BC2 in SD for example I found nearly impossible.
