msmalls74 said:I got this on rental last week, also got it on PC, to be honest i enjoyed it more on the PS3. PC looks better but i couldnt get on with it for some reason, I had one little frame rate judder in the middle of a fire fight when i launced a couple of smoke grenades by mistake. Nothing major though, didnt seem to have as much light bloom (which annoys me) as the PC version. I'd rent it first if possible, If i hadnt got it on the PC i would probably get it on the PS3, not tried it online yet. Theres also an update coming soon for the PS3 version I read on the forum.
Inoshishi said:Try it online mate and tell us what you think
I dunno if I should grab this or GRAW2.
Inoshishi said:I dunno if I should grab this or GRAW2.
Inoshishi said:Worthy of a purchase or avoid?
tomanders91 said:Played it round a friends, whilst the 360 looks a bit sharper, they both play exactly the same (framerate wise) so go for it.
Joebob said:OP forget about all the "it's better on the 360" comments. If you actually have it running on a 360 next to you while playing the PS3 version then you will notice the differences - if you only have it on PS3 then you have nothing to compare it against so I'm sure you will be more than happy with it.
neocon said:FRAME RATE PROBS
much better on the xbox 360
Stellios said:And to be frank, its ran like a bag of bolts on the 360 in many place, which is the main reason i got rid of it on the 360..
dannyjo22 said:One of the few 360 games i've played that was solid and smooth 100% of the way through the game. Strange yours wasnt, your console must be half dead![]()
Stellios said:Do the casino mission at the start outside, throw a smoke for cover and double check its running smooth. I turned it off after then as it got annoying.
msmalls74 said:May try when i get back in, did notice that your friends list is displayed in the game, much like RFOM. Wont last very long online though![]()
