Ok, I have a list of all the technical specs of the PS3 below... but I need help to fully understand it all.
Technical Specifications
CPU: Cell Processor PowerPC-base core @3.2GHz; 1 VMX vector unit per core; 512KB L2 cache; 7x SPE @3.2GHz; 7x 128b 128 SIMD GPRs; 7x 256KB SRAM for SPE; 1 of 8 SPEs reserved for redundancy; Total floating point performance: 218 GFLOPS
GPU: RSX @550MHz 1.8 TFLOPS floating point performance; full HD (up to 1080p) x 2 channels; multi-way programmable parallel floating point shader pipelines
Sound: Dolby 5.1ch, DTS, LPCM, etc. (Cell-base processing)
Memory: 256MB XDR Main RAM @3.2GHz; 256MB GDDR3 VRAM @700MHz
System Bandwidth: Main RAM 25.6GB/s; VRAM 22.4GB/s; RSX 20GB/s (write) + 15GB/s (read); SB 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance: 2 TFLOPS
Storage: HDD Detachable 2.5" HDD slot x 1
I/O: USB Front x4, Rear x2 (USB2.0); Memory Stick standard/Duo PRO x1; SD standard/mini x1; CompactFlash (Type I, II) x1
Communication: Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x3 (input x1 + output x2); Wi-Fi IEEE 802.11 b/g; Bluetooth Bluetooth 2.0 (EDR)
Controller: Bluetooth (up to 7); USB2.0 (wired); Wi-Fi (PSP) Network (over IP)
AV Output: Screen size 480i, 480p, 720p, 1080i, 1080p; HDMI HDMI out x2; Analog AV MULTI OUT x1; Digital audio DIGITAL OUT (OPTICAL) x1
Disc media:
CD: PlayStation CD-ROM; PlayStation2 CD-ROM; CD-DA; CD-DA (ROM); CD-R; CD-RW SACD; SACD Hybrid (CD layer); SACD HD DualDisc; DualDisc (audio side),DualDisc (DVD side)
DVD: PlayStation2 DVD-ROM; PlayStation3 DVD-ROM; DVD-Video DVD-ROM; DVD-R; DVD-RW; DVD+R; DVD+RW
Blu-ray Disc: PlayStation3 BD-ROM; BD-Video BD-ROM; BD-R; BD-RE
I understand most of this but what exactly is a terraflop? and how does it compare to most CPU's in a PC or even against the PS2 or XBOX360?
What exactly is the difference between 480i, 480p, 720p, 1080i & 1080p?
Disc media:
I wouldn't say any console out of the PS2/Xbox/Gamecube is neccesarily better than the other. All have their good games, and their bad games.
