PS3 - Using PC Monitor/Sound?
12 Dec 2005
If I hook a PS3 upto my PC Monitor, is it possible for me to get sound in anyway comming out of my PC speakers?
Cheers
Does your monitor have a line out? As you could use the HDMI audio capability, connect your PS3 to your monitor, then use the line-out of your monitor to connect your PC Speakers and they'd work in theory. That's how I've had it done and it's fine.
If not you would have to output the sound out of the optical output or av phono lead to another amp or similar ( something you input into) then output to pc speakers or normal speakers.
I have also seen people suggesting a USB sound card, tho I don't know if that would work
