Hey folks,
I got a problem with my PS3...
I moved a few weeks ago and wanted to connect my PS3 today, but it won't work...
It says the connection works fine (when I test it) and is active, but whenever I try to connect it, it says it needs a system update, I start it and then it always fails at different points - sometimes I get to the download and it gets a disconnect error during it, sometimes I don't even get that far.
The connection should be fine - I'm using the WiFi all the time with my laptop and normal PC and there are no problems at all.
I got a Japanese special edition, but that shouldn't be a problem
I tried to disable the streaming options but still no success.
In my old flat I had it hard wired to the router but I can't do that here anymore since the router is on a different story ...
Kinda desperate by now - any ideas?
Thanks in advance!
PaloPolo
Thanks in advance!
PaloPolo
