PS3 wireless connection/extension
8 Apr 2003
NFA
Quick summary of the problem. My landlord has a ps3 installed in his work van (including a full hd 42" lcd) which we game on most evenings after work. We'd like to get it online but with it being in the back of the van the signal is blocked.
Range of wireless router is fine as can connect to a decent level a good 50ft from the house so how do we get around this?
I'm hoping there is an adapter we can run via an extension cable to put outside the van?
If I visualise this right, you are after some sort of cable to extend the reception of the wifi adaptor? Like on PC's when you use a USB dongle for wifi you would use a USB extension lead to extend the aerial for better placement/range.
In the PS3 the antennae is inside the PS3 so you would have to physically move the PS3.
We need pictures of your ghetto, inside-a-van setup, tbh.
rp2000
