PS3 wireless problems
17 Feb 2011
This problem is really annoying me now. I was connected to psn and it was working fine and suddenly it disconnected and wouldn't work at all. I tried the usual fixes such as leaving the router off for 10 minutes and the ps3 but I still can't connect. All the other wireless devices are working fine bar the ps3.
The problem I'm getting is the ip is timing out. I entered the ip manually and it succeeds in the connection test but then internet connection fails. I'm kinda stuck at what to do now so does anyone have any suggestions in how to fix this?
Reset the router to factory defaults and try connecting again. That should work. It sounds as if the router may have some sort of DHCP issue. Also, check you haven't enabled MAC Filtering.
