PS3 with XP media centre
3 Feb 2006
The Shire (of Hertford)
Hi there,
I'm getting a PS3 and was wondering how easy if at all possible it is to play all my music and videos on my media centre PC which is connected wirelessly to a hub.
Will the PS3 detect the PC automatically or are there some hoops to jump through first ?
Thanks
Sunrunner
Not done it myself with media centre (I use TVersity) - But that was really easy to setup and the PS3 saw all my files no problem.
You don't need media centre or TVersity. Since the patch before xmas, you can just share a folder containing what you want the PS3 to see from within Media Player 11 and the PS3 will just play it. I've not found anything that doesn't play yet, but bear in mind that some codecs are not supported (divx/xvid works fine for me).
