PS3s faulty
I'm on my second PS3, as the drive on the first one stopped working..
On a positive note I had a courier on my doorstep two days later with a new one for me :)
Now that's what I call customer care..
took mine back today and got a replacement,aparently the 40gig one's have had a few failures since coming out,seems a common problem as the guy had had about 4 or 5 this last week or so,wether it was a batch of them or sony using cheaper parts for the 40 gig models it's anybodys guess.
The drive issue isn't a 40GB issue, it has been happening with launch 60GB's too.
See this thread: http://www.ps3forums.com/showthread.php?t=113728
On other news my 40GB did the exact same thing, it froze on Uncharted and after rebooting it won't read discs, the drive doesn't even spin up.
So it sounds like what was said on the PS3 forum, the drive controller must have shorted out.
Gonna get it replaced from a certain shop in a bit.
Don't know if you read this before you return yours, But "deactivate" the ps3 you return. Each PS3 master account can be accessed on 5 PS3s, your broken one is already counted as one, unless you go into account management and deactivate it before you take it back to the shops. It's unlikley you will need all 5 of you licenses but it can be useful if you have more PS3s break, o you wish to share you paid games with 4 other people etc.
rp2000
rp2000
Ah cheers I forgot to do that on this faulty one but I will do on the next. :D
Thats gutting Jihad!
Thankfully it can replaced quickly. Also, your thread got locked! :p Be good if Zefan actually read the thread!!! Haha!
Won't he need the license for Warhawk as thats 1 per console?
Josh
Josh
No,
If he logs on with the same account as his previous console, Warhawk should work fine. The only difference with Warhawk as opposed to everything else is that you need to be logged in as the "buyer" account to play it. Assuming no-one at the shop he returned it plays with his account, he should be OK :D
rp2000
Josh
I know, less than 1% PS3 failure rate or so and that dies on me, only had 1 360 out of my 3 die and that's got 33%!! :p
I got it replaced now and yeah I was wondering what Zefan was going on about. :D
No,
rp2000
Made sure I deleted the account before I took it back. :D
