- 3 Oct 2014
This is how I updated my UK PS4 to beta
Download + Run Charles Proxy
Set up PS4 to use a proxy, point to computer IP on port 8888
Attempt a System update.
In Charles Proxy, expand FUK01 entry,
Right click PS4-updatelist.xml and Map Remote
Host: fuk01.ps4.update.playstation.net
Path: /update/ps4/beta/list/uk/ps4-updatelist.xml
http://duk01.ps4.update.playstation...a86a7dde26ea352caf88769/PS4UPDATE.PUP?dest=uk
Download and place on a USB drive in the folder PS4/UPDATE
Plug USB into PS4 and don't take it out
Turn off PS4
Hold power button down until second beep for safe mode
Update the Firmware via the Internet, you will get an error.
Update the firmware via USB, it will look like it installs but you will get an error
Restart PS4, login.
Hold PS button and sign out, this is when the Update File got added to the Downloads notification and is the only way it installs.
I gave up as I could get it appearing in the downloads, it took half an hour of messing around, but when I signed out this started the update download.
Turn off PS4
Restart PS4, login.
