- 8 Aug 2010
- Oxfordshire
The Op tries to genuinely contribute to this forum. Then get's trolled and provoked into a reaction until he get's suspended. Trolls live to troll another day.
i did it for better cooling, everytime i feal my consoles get hot i get images of the soldering inside melting lol
i went through a billion 360's in the space of a few years, i've had every launch sony console on launch day and only one of them has every died on me and that was after 5 years and 11 months, sony know how to make consoles, they aren't cowboys like MS.
PlayStation 4's operating temperature is listed as being between five and 35 degrees Celsius, which is cooler than the PS3. While Sony's current console is meant to run between 45 and 55 degrees Celsius, if it peaks at over 60 degrees you could encounter the infamous Yellow Light of Death, which essentially reduces your PS3 to a paperweight.
Oh dear the PS4 i use is faulty then?, because the heat that comes out of the back of this console is as hot as my GTX 780 at full load, i wouldn't want to put the PS4 on a glass shelf that's for sure, i'm a tad concerned about the ethernet, hdmi and power cables they get the full heat exposure.The console gets warm yes.
I'm all for mods that actually serve a practical purpose or improve looks, this however doesn't as it's "fixing" a problem that only seems to exist in the OPs paranoid head...
The console gets warm yes, but it's supposed to within certain tolerances. I think this is why he's had the largely negative reaction.
If he thinks a PS4 gets too hot, I'd hate to see what he'd do to an iMac that's just done something intensive![]()
You don't know if it's actually worked, you just know that you haven't killed your PS4 (yet).
Pure trollage from over zealous fanboy
That looks like a blower fan, like reference AMD cards, so it blows the air out the exhaust.
Surely now it's taking in colder air and blowing that through to the exhaust, I can't see why all the hate to be honest![]()
no, a comparison would be that he's taken a high performance car and then instead of letting it using it's own air intakes/exhaust, etc he has drilled a few holes here and there.
That looks like its mounted on the underside, and it pokes out a bit so its not flush with the case anymore, how is air getting into it? Surely it doesn't sit flat anymore and is raised at one end?
