Plug it back in to the other TV and set the output at 520p then plug it in to the new TV and see if you get a pic, if you do then set the resolution to match the TV
Pretty sure you can reset the video settings as follows: hold the power button til it beeps once, then keep holding it for about ten seconds till it beeps two more times then it'll boot up in safe mode
