22 Mar 2015 at 13:53 #1 drs101 drs101 Associate Joined 22 Mar 2006 Posts 1,186 Anyone have a ps4 hooked up to a displayport as my monitor only has this option.
22 Mar 2015 at 15:00 #2 BattFink BattFink Associate Joined 13 Jun 2013 Posts 937 Location Brighton(ish) Haven't tried it myself, but can't see any reason why it wouldn't work You would need something like this though - http://www.overclockers.co.uk/showproduct.php?prodid=CB-023-SR
22 Mar 2015 at 17:59 #3 drs101 drs101 Associate OP Joined 22 Mar 2006 Posts 1,186 Cheers just been googling just a bit confused about the male female part in regards to what i need
22 Mar 2015 at 18:09 #4 Kreeeee Kreeeee Man of Honour Joined 13 Jul 2004 Posts 44,092 Location /* */ drs101 said: Cheers just been googling just a bit confused about the male female part in regards to what i need Click to expand... I read that out of context
22 Mar 2015 at 18:10 #5 drs101 drs101 Associate OP Joined 22 Mar 2006 Posts 1,186 Lol ok, im sorted on that front ......
22 Mar 2015 at 22:08 #6 Chaos Chaos Soldato Joined 20 Oct 2002 Posts 5,603 Will that cable work ? Op needs Hdmi to Displayport but that one is Display Port to Hdmi. I dont think it works both ways or does it ?
23 Mar 2015 at 08:56 #7 drs101 drs101 Associate OP Joined 22 Mar 2006 Posts 1,186 Chaos said: Will that cable work ? Op needs Hdmi to Displayport but that one is Display Port to Hdmi. I dont think it works both ways or does it ? Click to expand... yeh i think i need dislayport male to hdmi female, so you then plug into the diaplayport and the hdmi into the adapter and hdmi into ps4
