Ps4 to gsync (not looking for gsync to work just to use ps4 on it)
13 Mar 2013
Is there anyway to get a ps4 working in a gsync monitor with a single dp connection? I've got a xb240h and purchased and active display port to hdmi and it won't work. Any ideas?
Have you considered using remote play? Will be a bit of a problem to setup initially if you don't have a spare HDMI screen but afterwards should be fine:
https://remoteplay.dl.playstation.net/remoteplay/lang/gb/index.html
Thanks :), I never knew you could do this.
Am having a go at setting it up now..;)
EDIT:WOW the PS4 picture across remote play looks really rubbish compared to what it looks like when connected directly to the TV, Looks like what an old movie looks like or something....
Took a few pictures of remote play vs wired direct to TV
Can you tell which side is remote play ...:p
You could use an Avermedia Live Gamer (any version) I guess, or Elgato etc etc. I have my Liver Gamer Extreme hooked up to my PC so I can play games at my desk as well as my tv, all I've gotta do is open up REC Central which is the software with Avermedia.
I've got 2 ROG Swifts.
