PS4 - Too many USB Devices Connected
  • Thread starter Thread starter smr
  • Start date Start date
smr
smr
6 Mar 2008
Leicestershire
Hi,
I've tried everything I can think of - I've unplugged the PS4 and left it, restarted, nothing.
I can't rebuild the database in safe mode because when I plug the controller in via the cable nothing happens.
The controller is fully charged as I've plugged it into a wall socket via a USB adapter.
Any ideas as to what I can do? I bought it in 2013 so it's well out of warranty.
Try an alternative cable or port.
Otherwise try a different controller.
If you have a powered USB hub you could plug that to the ps4 USB socket and connect the controller to the hub (this should draw less power from the ps4 itself).
  • Like
Reactions: smr
Thanks, tried a different controller. I do have a power usb hub, I'll try that.
