| PlayStation 4 | PlayStation 4 Slim |
| CPU | 1.6GHz 8-core AMD custom "Jaguar" CPU | 1.6GHz 8-core AMD custom "Jaguar" CPU | 2.1GHz 8-core AMD custom "Jaguar" CPU | |||
| GPU | Integrated AMD graphics clocked at 800MHz with 1.84 teraflops of performance | Integrated AMD graphics clocked at 800MHz with 1.84 teraflops of performance | Integrated AMD Polaris graphics with 4.2 teraflops of performance | |||
| RAM | 8GB GDDR5 | 8GB GDDR5 | 8GB GDDR5 + 1GB DDR3 | |||
| Storage | 500GB (5,400rpm) replacable hard drive. | 500GB (5,400rpm) replacable hard drive. | 1TB replacable hard drive. | |||
| Dimensions | 12. x 10.8x 2 inches | 11 x 10 x 1.5 inches | 12.8 x 11.6 x 2.1 inches | |||
| Weight | 6.2 pounds | 4.6 pounds | 7.2 pounds | |||
| Color | Black or white | Black | Black or white | |||
| Optical Drive | Blu-ray/DVD | Blu-ray/DVD | Blu-ray/DVD | |||
| Networking | Gigabit Ethernet, 802.11 B/G/N, 2.4GHz, Bluetooth 2.1 | Gigabit Ethernet, 802.11 B/G/N/AC, 2.4GHz, 5GHz, Bluetooth 4.0 | Gigabit Ethernet 802.11A/B/G/N/AC, 2.4GHz, 5GHz, Wi-Fi, Bluetooth 4.0 | |||
| Internet Subscription | PS Plus required to play online | PS Plus required to play online | PS Plus required to play online | |||
| Ports | HDMI, analog-AV out, 2xUSB 3.0, AUX, S/PDIF | HDMI, analog-AV out, 2xUSB 3.1, AUX | HDMI, 3x USB 3.1, 1x Gigabit Ethernet, 1x PS Camera, S/PDIF, AUX | |||
| 4K Support | Yes (video only) | Yes (video only) | Yes | |||
| HDR Support | Yes | Yes | Yes | |||
| Release Date | November 15, 2013 | September 15, 2016 | November 10, 2016 | |||
| Release Price | $399.99,€399.99, £349.99 | $299.99, €349.99/£299.99 | $399.99, €399 / £349 | |||
| Current Price | $299.99, €349.99/£299.99 | $299.99, €349.99/£299.99 | $399.99, €399 / £349 |
Definitely worth picking up a Pro over the regular PS4. There is an additional boost mode which helps with framerate for quite a lot of games. Also the '4K' games can be downscaled. I think most typically run at 1440p or below, but display at 4K resolution. Some trickery with checkerboard rendering as well.wow, faster clocked cpu, 1 gig extra ram although dunno why its ddr3? and gpu power seems to be doubled.
so just runs games at 4k? any difference if you dont have a 4k tv ?
wait, dont these consoles run games at locked 60 fps?Definitely worth picking up a Pro over the regular PS4. There is an additional boost mode which helps with framerate for quite a lot of games. Also the '4K' games can be downscaled. I think most typically run at 1440p or below, but display at 4K resolution. Some trickery with checkerboard rendering as well.
Edit: If you have any interest in PSVR, the Pro is a must.
60fps on console? What is thatwait, dont these consoles run games at locked 60 fps?
Buy a ps5 for better frame rates in most games.wait, dont these consoles run games at locked 60 fps?
This. No point getting a PS4 Pro at all unless its like 100-150quid.If you going to buy a console, pay the extra and get an PS5 as its over 2 years old now and it can play most PS4 games.
