PS5 HDMI 2.1 4k 120hz HDR monitor (max 28")
26 Dec 2012
Hello,
I am after a monitor for the ps5 that will do 4k max 28" due to space constraints, I need it to be 120hz (HDMI 2.1) and 4k and HDR. My area of expertise is not into monitors at all, could anyone recommend one for me I have been looking at the Sony Inzone M9, or the
BenQ MOBIUZ EX2710U .​
Speakers on the monitor is a plus, but they dont have to be that good, but obviously the better is good. Budget max £1000. Curved is not important. (I prefer non curved, but for the right one I willing to go curved).
I think the BenQ model you linked to would be ideal for you, and the built in speakers and remote are a bonus.
Another option to consider would be the LG 27GR93U it's LGs latest gaming monitor, don't think it has speakers though.
Thanks how about something like this?
Not worth the money over the BenQ or LG unless you want the extra HDMI and philips ambilight feature.
There all IPS based panels probably made by LG so performance will be similar it just depends what features you want.
Thanks for the advice I think i will go with the benq one, I will try to get measure to see if I can fit the 32" version one first though.
LG 27Gp950 4k 160hz full bandwidth hdmi 2.1 for the console 120hz.
Excellent Ips panel I can recommend this monitor with the latest firmware update.
