PSA - DS1, 2, 3 and Elden Ring critical vulnerability
1 Dec 2006
Amsterdam, NL
Edit: blue sentinel isn't effective against the vulnerability and until officially patched, it's advised to play offline. Bandai Namco are aware. Thank you @Grim5
The community has discovered a critical weakness in the games base code which allows machine level control from attackers. It was even demonstrated in a guys stream by the guy who discovered it. He took over his computer, closed the game, opened powershell and had it narrate a message.
Bandai Namco are famous for not listening to the community so my advice is to install Blue Sentinel which is a community mod used to stop cheaters when playing online. The creators of this mod are aware of the exploit and working with the person who discovered the weakness.
https://www.pcgamer.com/psa-dont-pl...mote-code-execution-vulnerability-is-patched/
Blue sentinel doesn't work against this exploit sorry. Only thing you can do is play offline.
bandai namco have acknowledged the issue, if it can't be fixed by launch the PC servers will be offline at launch until it's fixed
another reason for all software including Games to go through full security compliance by A/Multiple trusted authority before release.
Google/MS/Apple are planning to do just this for the web But we need it for software as whole
we do it at our company with software with 20 million+ lines of code
Running it through Vulnerability scanner in depth mode takes 30 minutes to 1 hour, no reason companies could not automate this & rule out 98% of security issues that arise
But companies in general see Security as not required for games
Ah, thank you, I just saw the news, I'll update the original post.
Not sure with games it is as simple as that - some stuff like remote console vulnerabilities can be completely transparent to automated security analysis.
it wouldn't pick up Every issue but it would pick up some of the console vulnerabilities in the last few years & it would 100% pick up game companies leaving Network ports like 9530-12000 open without Authentication from a trusted source looking at you COD, EA in general
At least it would protect against most silly mistakes
Vulnerability scanners now learn from previous Failed states so as users input new vulnerabilities d to the DB AI then does that & attacks it variety of ways users could not dream of
AT the end of day @Rroff anything is better that we currently have.
That is it appears to no game company actaully protecting their customers
