Hi,
I trust I'll literally be able to buy the Datel battery, create my magic memory stick using PSP Grader and install 4.01 M33-2 with no troubles? (I'll be following this: http://www.orderoftheflame.co.uk/blog/?page_id=788). I don't need to check I have any specific type of motherboard/version of PSP do I?
My main question though is: would I be better off getting the Datel, or a Pandora battery?
I plan to keep it for future use in case I ever install some dodgy home brew that ends up bricking my PSP.
Oh, and is the method shown in the link above better than the Pandora's GUI method?
[Edit]
Can I install 4.01 M33-2 straight away, or do I need to do 4.01 M33 and then 4.01 M33-2?
[Edit]
Can the Datel battery be used as a normal battery for the PSP? I found one for £12.99 from a famous website, I think it's a small price to pay to breath new life into my PSP
I know they can be got cheaper from America, but I don't want to risk paying customs, having delayed delivery etc.
Thanks,
Craig.
[Edit]
[Edit]
Thanks,
Craig.
