PSP Help
1 Dec 2003
Liverpool
Hey,
I managed to get hold of a PSP (fat version) which has no battery or battery cover.
Everything seemed to work, although the wireless does not.
When i try to scan for networks i get internal error: 80110A0B
Not good! Any suggestions, also i cant update the PSP version as i dont have a battery...dang!
(dont worry i didnt pay for this)
Surely a cheap battery can be sourced, does sound broke but mabye a bad firmware flash has done that
Be worth a go flashing it to see what happens?
Yeah im going to try get a battery, i wont be buying one as i think it will be definetly broken and i dont really know any high street stores i could jus go get a cheap battery at.
Formatted a few times and gone abck to default no luck
That error code means hardware failure. Just call up Sony tbh. I think they fix them out of warranty as well for a nominal charge, but I don't know the details.
rp2000
