PSP Memory Stick Duo?
6 Nov 2002
Its my brothers birthday coming up and he is after a few Memory Sticks for his PSP. I have been looking at the 4 gig SanDisk Due Pro ones, do these work? Anything to look out for when I am buying them?
You help will be most appreciated :)
there is a thread on the forums at yourpsp.com iirc about 4GB sticks, think it might even have some suppliers, think popular cheap places are ones that sell mobile phone stuff? i would like directly, but it may be a competitor.
I was looking at them the other day and found that you can get one for £80 or there abouts. It depends if you want one large one, but two smaller ones might be a lot cheaper if that is an option.
:eek: was that £80 for a 4gb stick or did i just read that wrong :confused:
I think the latest firmware 2.8/2.81 removed something in order for the higher capacity cards to work (up to 8GB). So all of us on 1.5 are stuck with a maximum of 4GB at the moment.
