Psp Speakers
18 Oct 2002
Liverpool :-)
Hi all,
While the speakers on the psp are decent, they arent loud enough to play music at a decent level. I've just returned from my hols and i want a set that arent to bulky/big to travel with and plug in the wall.
Any recommendations on what to buy at a decent/cheap price?
£55
PSP Nyko Theater System
The Nyko Theatre System must be the fanciest PSP case around!
The Nyko Theater Experience is a must have for your PSP - as it is designed to enhance the overall functionality and play quality.
The case is a good-looker to start with - made from stylish black brushed aluminium. Built in to this case is a rechargeable battery, amplified hi-fi stereo speakers and a PSP stand that opens to the ideal PSP viewing angle.
Not just good looking, but practical, the incorporated lithium-ion battery adds 7 hours additional play time battery life for marathon movie and gaming sessions. The Theater Experience will even recharge your PSP 2 or 3 times before needing to be recharged itself.
The dual headphone jacks mean that you can enjoy movies with a friend by connecting a second set of headphones.
All of this plus an audio line in port and a power extension cord for using the PSP outside the case are included.
The outside case is designed with a form-fitted neoprene lining that keeps the PSP safe and secure.
A superb choice to protect your PSP and let you get the max out of it too, making the PSP into a home theatre system, wherever you may be!
So kick off your shoes..... relax and enjoy all your PSP has to offer, while your Nyko Theater System cradles it for you!
PSP Nyko Theater System - Features:
* Stylish aluminium case with built-in rechargeable battery, speakers and stand
* Play, charge or listen to PSP, in or out of the case
* Dual headphone jacks
* Adds 7 additional playing hours of battery life to the PSP
* Uses PSP AC Adaptor
* Included AC and stereo cables allow you to play, charge or listen to the PSP outside of the case
What's In The Box:
1 x PSP Nyko Theater System Case
These sound better and are cheaper too. £40.
Review
This is a great portable mini speaker system for the PSP. The whole unit matches the PSP in style and size, whilst the sound quality is surprising for such a small pair of speakers.
It does produce a decent level of sound, but definitely not enough to throw a party. More like 'radio in the kitchen' levels. Great though for playing a bit of music in the office, or improving the sound quality for a movie. The sound is not 'tinny' like some mini Speakers that you find.
It takes less than a minute to set this system up after being packed away. You simply twist the speakers to the upright position and pull the stand out at the back The PSP sits securely in a cradle that clips to the front of the amp. Two different length audio cables are provided so that you can choose to operate the PSP in your hand instead of attaching it to the unit. The unit is powered either with four AAA batteries or the supplied ac adaptor.
The system also comes supplied with a good quality travelling case. It's very compact because the speakers themselves can fold up for storage. This case could easily fit inside either a briefcase, or a womens shoulder bag.
£100
VIDEO - http://www.expotv.com/videos/expo/203/238/TannoyDigitalPSPSpeakerSystem/237052
Tannoy Premium PSP Speaker System
# Output Power 2 x 25W RMS.
# 2 x 75mm (3 inch).
# 50 Watts RMS total power outpu.
# SRS TruSurround: Improves dialogue clarity and deepens and accentuates the bass response with its TruBass enhancement feature. Delivers a premium Virtual Surround Sound experience.
# Recharges your PSP Console.
# Full Function Infra Red Remote Control.
# Soft eject fold up base for ease of portability.
# 3.5mm auxiliary input (1.5 metre Audio cable included).
# Black Gloss Finish.
Gameplay: Connect your PSP using the 1.5m audio cable (included) via the auxiliary audio input, sit back and enjoy the experience in virtual surround sound with SRS TruSurround.
Movies & Downloads: Dock your PSP into the Speaker System and enjoy the full dynamic performance of your soundtracks like never before in virtual surround with SRS TruSurround.
Music: Connect your external audio devise (iPod, MP3, etc.) using the 1.5m audio cable (included) via the auxiliary audio input and listen to your tunes in high quality stereo reproduction.
review
I bought this with more than just a PSP dock in mind as u can connect an external source with the minijack input on the back.
It really is very good, I have it sat on my unit infront of TV ( and have it connected to use instead of my Tv speakers) to good effect i must say.
The Front dock section that the PSP sits in has a kind of damper effect when pressed and releases down slowly and buttons have a cool blue glow when switched on. Remote is simple but works well.
Sound wise it's great, very nice detail and decent and fast bass, a little lacking in bass at times so dont expect huge bass when used with the PSP due to the limited equalizer options of the PSP, But what bass u get is good bass. Works great with my Iriver H120, also works very well with input from my TV. As always the better the quality/bitrate of music the better the result.
All in all this is far better than i expected and is still growing on me, sounding better all the time as i get used to it.
Sounds good to me, looks quite compact as well. Could be the winner already lol, cheers robert
Although they were the logic 3 speakers, but look the same sort
