PSP UMD Drive
Caporegime
18 Oct 2002
Lake District
Well after not using it for a long time (years?) I decided to start using it again the other day only to find it won't read UMD's properly, it spins up fine, but a clicking (like seeking) can be heard from the laser, the motor is spinning up fine and the laser is glowing red.
Is there a simple fix or might I just as well buy another?
Not sure how to fix your issue I'm afraid.
But I would just like to say that I find the UMD drives can't be relied on. The first one I ever got stopped working within a week as it wouldn't read. The second eventually somehow wouldn't shut anymore (though I took really good care of it). The third seems fine and has run for a couple of years now, always worried it's gonna go though!
Have to say I still prefer them to the later PSPs that were D/L only.
** Quote removed **
Its bad that 2 out of 3 of your latest posts in Consoles are about cracking. Which if you look 3 posts down from the top, the stickied post! You'd know such talk isnt allowed here
