- 22 Jul 2015
- Aberdeen
Most of the components in the case. Build taking some shape now
Those cables look excellent threaded through the comb, it gives it a nice clean look instead of being messy. The colour co-ordination on the motherboard, cables and RAM also looks fantastic
Just wondering why you used Corsair fans on the front radiator and Viper fans on the top radiator. Do they have different RPM ranges or is just aesthetics![]()
Ah I see, must admit I wish Corsair did some SP140 fans with the coloured rings, LEDs just look garish. The setup looks good though as the white fan blades compliment the red and white cablesTop rad is 420mm so requires 140mm fans. Corsair 140mm high static pressure fans are LED and are rated at 1.46mm/H2O. I do not want led fans so I am using Akasa 140mm fans, which are rated at 3.1mm/H2O. Plus I already owned these Akasa fans and just painted the blades white to fit the build theme![]()
Great progress mate, looking really slick. Very nice block that!
So, red or white coolant?![]()
white. gpu blocks and backplates will be white too![]()
Nice, going to match in perfectly with fans / cables. Look fwd to next update mate
stunning love the colours the red and white cables sure do stand out
Nice to see a new update. Your tubing runs are excellent as they are precise and straight. Can't wait to see the filled loop![]()
Very nice work on the tubing. Gonna start mine in a few weeks, doubt it will be as remotely clean as some of these bends![]()
Does that Motherboard have a brown PCB, or are my eyes deceiving me.
Awesome work
