PSU 12V CPU cable Mod
Permabanned
19 Nov 2008
Peterborough, England
I want a motherboard with an 8 pin 12v CPU cable socket if i buy an 8 to 8 pin extension cable and adapt it for a 4 pin cable will it work? Is the any reasoning behind 8 pin voltage wise?
Your 4 pin cable will fit in one side of the 8 pin socket without the need for any adapters.
My last motherboard had a blanking plate in one side of the 8 pin socket that I had to remove before I could use an 8 pin cable.
