Got a nasty feeling I know what the answer will be but.........
Have an Aerocool550w psu and the problem is the 12v rail is reading 1.68....just started doing this and I was wondering if anyone who has some experience of psu's (mine is very limited) would know if there would be a particular reason for this, or could suggest a fix?, or even if one exists?
Pc fires up fine but seems very slow, will play COD online with no apparent problem.
System spec is
FX53
6800GT
MSI K8N Neo Plat
2 x 1GB Corsair XMS3500LL
NEC DVDRW
Watercooling to cpu and gfx
Any suggestions gratefully received as to a fix as the psu is in a watercooled unit and I dread having to take it all out again
System spec is
FX53
6800GT
MSI K8N Neo Plat
NEC DVDRW
If that was the case methinks you would not have a functioning PC.
