PSU +12V showing +10.37v - PSU sick?
11 Aug 2003
UK
My PC has been experiencing occasional random lock up. So I thought I'd have a bit of a sniff round the PSU. I've installed CPUID Hardware Monitor. All the voltages are rock solid (+/- 0.02v), however the +12v is should as 10.37v with a min of 10.26v. Is this ok, or a sign that the PSU is on it's way out (or something else)?
Thanks
What PSU are you using, I would test with a multimeter mainly as I don't trust software readings for voltages.
Have you tried running mem test and Prime to check for stability.
It seems the software is unreliable. Since restarting the PC a few times, each time it gives a different reading!
I've used a multimeter on a connector and it shows a healthy 11.88v +/- 0.01v over a ten minute period.
So I'm not suspecting the PSU so much. I recently added extra RAM and an additional hard drive. When I did that, I ran memtest overnight in a room with no AC meaning an ambient of 30+C. It was rock solid then.
