Hi, I have a Corsair AX750 which I bought last year but only recently got around to trying to "tidy" up cabling in my Haf X. I've ran into a little issue with the 8 pin power cable being far too short to route through the back over to the top.
I've tried using an old extension that I had but it would load up properly, I would just hear the fans running at 100% continuously without booting windows up. I'm assuming it's a faulty extension. I'm wondering if Corsair might be able to provide a longer cable for it (currently had a 600mm from the looks of it), or should I just buy one of these and try it out?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-066-AK&groupid=1929&catid=153&subcat=
Would this be the right one though?
Cheers.
Cheers.
, not working properly leading to the above.
