PSU advice
Permabanned
24 Apr 2010
Lancashire
Firstly, why don't we have a PSU section on here? Lol
Looking at getting a power supply to power the following PC:
Intel Core i7 860 CPU
4 or 8GB DDR3 Ram
2 x GTX280 Graphics Cards
1TB Samsung F3
2 x SATA DVD Writers
and a couple of decent fans.
I've seen a Powercool 950W Quad Rail PSU on the MM for £50 but I'm just wondering if something like the OCZ StealthXStream 2 600W would be more reliable and would a 600W PSU power the above computer?
The PC the PSU is for will never be used for gaming, it's going to be used with projectors in a church which is why budget is somewhat an issue. Good to know Coolermaster PSU's have been good for you though :)
Sorry misread, thought you were listing GTX 480s. Will check power requirements of two GTX 280s now.
But don't get the Cooler Master GX 750 yet, because it has a lower temperature rating than other high quality units and been poorly reviewed because of it.
Ok, appreciate your help and will await your reply :)
Ok, Guru3D showed the power draw of a PC running two GTX 280s to be 530 watts, so a good 650W PSU with two 6-pin and two 8-pin PCI-e connectors would be good enough. And the 650W version of that XFX fills that requirement:
XFX Pro 650W Core Edition 80Plus Bronze £69
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF&groupid=701&catid=123&subcat=
If there isn't going to be any gaming then why do you need two gaming cards, surely you could just use one?
Thanks, I'll have a look at that XFX. Still a bit more than I was looking to pay but hey.
The reason for the 2 cards is we need one output for the monitor, one for projector and one/two for the monitors that will go on the stage...pain I know.
Not really, as the efficiency is higher on the whole XFX range compared to the old TXs. And the 650TX doesn't have enough PCI-e cables, so you would have to use adapters.
Thanks Essexraptor. I think it's probably a good idea to go with the 850 XFX which will give me head room when we add a second card or incase we decide to add extra hard drives, etc.
As a general rule of thumb, if you were buying a second hand psu, what's the oldest (in age) you'd buy? Trying to toss up the difference between a new XFX or a used Enermax for £22 less
But why exactly 2x280gtx's? You could get 2x220gt's to do the same job, or theres a multitude of AMD options that have between 3 and 6 outputs on a single card, from low end to high end, then you've got Matrox for multi-output cards.
This is for a church to run several displays off, 2x280gtx's feels like insane overkill, what else will they be doing, unless you're running intensive Cuda apps then if you're not gaming a high end card is a complete waste.
Likewise a simple low end gpu or pair of gpu's means you'd be both saving 200-300W in power usage which will save money, cost less initially, and allow the use of a quieter, cheaper, lower power PSU.
