- 23 Nov 2005
- Kingdom Of Fife
My Corsair HX620 is a very efficient PSU especially at load (83%)
Does this mean if measuring power consumption with a meter at the plug, it could draw a max of 750W mains to deliver about 615W (750 x 0.83) is this correct?, so if I'm about the 650W mark on the power meter, I should be OK with the PSU? (540W delivered from PSU)
Hope this makes sense!
Any advice would be appreciated!
Jonnygrunge.
Jonnygrunge.
If you try and pull more power than that then OCP will kick in and the PSU will shut down in order to prevent things getting too hot...
