- 11 Aug 2012
I was going to Order the coolmaster silent pro 500w but after being out of stock for ages they have now been removed from the site.
I was thinking about ordering a
http://www.overclockers.co.uk/showproduct.php?prodid=HS-080-AK&groupid=701&catid=2330&subcat=
so i can get my CPU overclocked and wondering if the
http://www.overclockers.co.uk/showproduct.php?prodid=CA-056-AK&groupid=701&catid=123&subcat=2227
are any good as i thought the 2 together in a windowed case would look better.
Any thoughts on the Akasa PSU's?
Are they any good?
and if not what suggestions do you have in the £50-£70 bracket but preferably cheaper the better as i am replacing a mistake i made when building the system.
Cheers
Are they any good?
Cheers
