PSU advice
2 Oct 2012
Just bought the following:
Be Quiet SFX 300W MicroATX
Thermaltake Armor A30 supports Standard ATX
Asus P8H77-M PRO H77 Board.
I am told that:
"The SFX 300W model unfortunately does not come with the adapter plate. You'd have a lot more room in that case if you can find one that does. I've search a bunch of UK sites and I cannot find any. You're likely going to have to get an ATX power supply. If you do, see if you can get a modular one -- though it's going to be just as hard to find a low power modular power supply as finding an SFX power supply that comes with the adapter plate."
Is this correct if so can someone urgently recommend something that will work.
