PSU advice
sorry
Thermaltake 650W Toughpower PSU
Aerocool Templarius Imperator 650W
The Thermaltake is 80plus, the Aerocool is 80+ Bronze. So it really depends on the price and the system it is going to power.
Post your PC specs and a budget for the Psu.
i5 3570K Not oc'd
8GB DDR3
500GB 7200
DVD RW
AEROCOOL XSTRIKE 500W
And im looking at adding a xfx 7950 dd
The thermaltake got great reviews
£60 is my lot for PSU
Yeah its not modular, I just don't want to kill the system, so if I need more power id rather just get one. I was looking at the aerocool Templarius Imperator 650W and that is under 50 quid. The reason I would choose the aerocool is because my current one is great, silent and no hiccups. But xfx recommend 650w for the 7950 dd
Your original PSU will be fine for a 7950.
Also please remove the competitor links and check the FAQ regards competitors.
Personally I wouldn't go for thw CX series. I recently had one and it had horrible coil whine, got it replaced and the new one had the same problem. Replaced it again for a TX series and no problems so far. They're roughly the same price as the CX series.
