PSU Advise
3 Apr 2009
Preston UK
My Hiper Type M 580W just died I want to replace it but don’t know which psu to go for I would like good cable management for my Case Cosmos S.
I should have been clearer at the start I wanted to know the exact Brand & model that would suit my system ( the large case size & components ) so I did some home work & came up with the Cooler Master 850 Modular
Coolermaster uses a lot of different manufaturers, so their range of quality goes from decent to pretty good, you need to do more research to get the best ones from them, than you would with some other brands.
Like I said I was not clear in what I wanted to know.
I wanted a PSU that would be up to the job in regards to wattage & also cable management.
I am grateful to the reply's I got, but I did digging around & decided on the Cooler Master it has had some great reviews.
